Старый 12.12.2012, 05:26
Аватар для Maxel
Maxel Maxel вне форума
По умолчанию Блока QUAIFE на каймане
вопрос возник
купил машину уже с блокой QUAIFE
сегодня выезжал заезжал из бокса
по снегу
резина летняя стоит(но это не важно)
буксуешь - и крутится только одно колеса
я чот не понимаю.... как так)))
блоки нема или преднатяг нуль там уже
у кого стоит?
Старый 12.12.2012, 05:49
Аватар для Maxel
Quaife ATB Helical LSD differential
Quaife ATB Helical LSD differential for Porsche Cayman S is suitable for Porsche Cayman S models, to replace the standard open differential. A direct replacement for the standard Porsche differential, the Quaife ATB Helical LSD differential transforms your car’s performance.
Unlike a conventional plate-style limited slip differential, the Porsche Cayman S Quaife ATB Helical LSD differential relies on gears rather than clutch plates for its operation. That means it is much smoother in operation.
The Porsche Cayman S Quaife ATB Helical LSD differential never locks harshly with a set pre-load of wheel slip across the driven axle, like a conventional LSD. Rather, the Porsche Cayman S Quaife ATB Helical LSD differential automatically biases the torque away from the spinning wheel across the axle, to a constantly varying degree, and never locks.
The Porsche Cayman S Quaife ATB Helical LSD differential has many benefits over a standard open differential, including maximising traction and minimizing wheelspin, eliminating torque steer and snatching in front wheel drive cars compared to conventional LSD units, and a maintenance-free design which retains the standard oil lubrication.
The Porsche Cayman S Quaife ATB Helical LSD differential is proven in circuit and drag racing, rallying and road use, and is produced from Corus steel billets, and is CAD designed and CNC machined, then inspected to ISO 9001 standards.
With over 370 applications, the Quaife ATB Helical LSD differential is second to none. Accept no imitations!
Quaife ATB Helical LSD differentials are used by Ford, General Motors and Daimler-Chrysler as original equipment.
The Quaife ATB Helical LSD differential for Porsche Cayman S is also now subject to a lifetime warranty (subject to terms and conditions).
Please confirm your application using the attached techncial drawing
Старый 12.12.2012, 05:50
Аватар для Maxel
или она и не должна блокировать жестко
а просто перекидывает
Старый 12.12.2012, 20:49
voodoo voodoo вне форума
Все правильно. У тебя gear type LSD
The problem of gear LSD (istead of clutch type LSD) is that when one tire has LITTLE or NO grip (zero axle-load), the other wheel gets ZERO DRIVE
Так что тебе надо взять дисковую блокировку - clutch type LSD. Например, Drexler или KAAZ
Старый 12.12.2012, 21:00
Аватар для Maxel
kaaz хочу
ну я так и думал
а вообще есть плюсы от этой блокировки, которая у меня стоит?
кто использовал?
Старый 12.12.2012, 21:17
Аватар для Maximus
Maximus Maximus вне форума
Дайте линков на KAAZ и Drexler на 996?
Аватар для Maximus
kaaz хочу
ну я так и думал
кто использовал?
Каз только на классику делает, насколько я могу найти.
Старый 12.12.2012, 21:37
Аватар для EuJohnus
EuJohnus EuJohnus вне форума
кто использовал?
Хорошая блокировка! и практически вечная!
Минус то, что у буксующего колеса должен быть хоть какой-то зацеп!
Старый 15.12.2012, 12:00
BFG BFG вне форума
По поводу дрекслера: когда я на дрифте разорвал привод, машина не поехала с дрекслером в редукторе. Так, слегка подергивалась на минимальной скорости, только если с горочки. (на Z4)
Старый 15.12.2012, 12:38
Stepler Stepler вне форума
у тя ж пп?зачем тебе?)
Старый 15.12.2012, 13:57
Аватар для MammoNT
MammoNT MammoNT вне форума
Кстати Drexler на 996т на механике лежит в наличии, за 100тр отдам
Старый 21.12.2012, 17:27
Аватар для EuJohnus
Кто нибудь может подсказать на Бокстере эС с ПАСМ в базе есть какая-либо блокировка?!
Старый 22.12.2012, 00:34
Аватар для Maximus
Да уже предлагал. Спасибо за 100тр пускай лежит там рядом с SSK и дальше .
Старый 22.12.2012, 00:35
Аватар для Maximus
Сообщение от Stepler Посмотреть сообщение
Почему нет? Там на пп есть и на морду кстати.
