-   -   LS7 двигатель внутри 930 (https://porschec.ru/showthread.php?t=5209)
*Guderian* 22.08.2012 17:30
Сразу хочу успокоить ортодоксов веры - ни один 934 при этом извращении не пострадал))))
http://cdn.speedhunters.com/wp-conte...8/IMG_0231.jpg
http://cdn.speedhunters.com/wp-conte...8/IMG_0239.jpg
http://cdn.speedhunters.com/wp-conte...8/IMG_0274.jpg
http://cdn.speedhunters.com/wp-conte...8/AY0F3461.jpg
http://cdn.speedhunters.com/wp-conte...8/IMG_0311.jpg
http://cdn.speedhunters.com/wp-conte...8/IMG_0248.jpg
http://cdn.speedhunters.com/wp-conte...8/AY0F3451.jpg
Specs:
Engine: GM Performance LS7 swap, dry-sump, Sand Buggy exhaust manifolds, Supermachine custom exhaust system
Driveline: 930 Turbo transaxle gearbox, custom short bellhousing & mainshaft with LSD, heavy duty custom axle shaft, KEP lightened HP clutch, custom hardened components & ring gear, diff & transmission oil cooler system
Front Suspension: Sachs coilover struts & Hyperco 350 lbs springs, Tarett Engineering 935 front suspension kit, Tarett Engineering sway bar kit, Elephant Racing quick change camber plate
Rear Suspension: Sachs coilover struts & Hyperco 450 lbs springs, Tarett Engineering 935 style spring plate, Tarett Engineering sway bar & drop link kit, Elephant Racing/Monoball Cartridges trailing arm
Brakes: Brembo Racing 4-pot front & rear calipers, 2-piece slotted discs
Wheels & Tires: Porsche Fuchs 8Jx16″ (front), 11Jx17″ (rear), Kumho V700 225/45R16 (front), 315/35R17 (rear), Hoosier drag radials 315/35R17 used for Motor Head Zero Yon event.
Exterior: 934 RSR look front bumper, Custom front canards & lip spoiler, RSR look rear spoiler, spoiler gurney flap
Interior: Recaro seats with harnesses, custom roll-cage, racing steering wheel, billet shift lever and knob
avega 22.08.2012 17:32
Жуткий проект.
Maximus 22.08.2012 19:29
Они оскорбили мои религиозные чувства, я наверное не смогу работать месяца два теперь как минимум(
New 22.08.2012 21:18
я одно понять не могу, нулевики почему такие пожмяканные почти во всех пиндосских проджектах
avega 22.08.2012 21:21
Они один и тот же из проекта в проект переставляют ; ))
St. 22.08.2012 23:07
Автора проекта на костёр!!!
DeN 22.08.2012 23:16
В "пендосии" любят сувать в Порше все что попало, сам видел 993 с мотором от Корвета....
New 23.08.2012 01:35
гм моторы у них на помойках валяются, вот и ставят куда ни поподя (образно)
главное что-бы наши умельцы с газа не присобачили в8))
Mara 23.08.2012 12:15
как охлаждается двигатель, спроектированный под водяную рубашку охлаждения? только маслом?
привет головке блока?
avega 23.08.2012 14:49
Судя по уродливости переднего бампера, радиаторы вынесли туда.
*Guderian* 23.08.2012 15:16
Сообщение от avega (Сообщение 84276)
avega 23.08.2012 19:20
Тогда простите : )
И тем не менее...
2A 23.08.2012 22:33
http://www.youtube.com/watch?v=T8mZAAhLFkc
а так можно, или тоже не годиццо?
*Guderian* 23.08.2012 22:44
Вам сюда: http://www.porschec.ru/showthread.php?t=3369
Текущее время: 03:22. Часовой пояс GMT +4.
