Продам AP5200 (4 Pot) / МОСКВА
Вложений: 3
СУППОРТА AP Racing AP5200 4 Поршня (Б/У)
Applications: - Performance Road Front. - Formula Brake Kits. Features: - Radial Mount, 152mm centres. - Suits Ø330 max / Ø304 min x 32 or 28mm thick discs. - Cast two piece Aluminium alloy body. - Aluminium alloy pistons. - Piston dirt seals fitted. - Black anti-corrosion paint finish. - Steel wear plates. - Pad anti-rattle clip fitted. Black Caliper Part Numbers: - TO SUIT DISC Ø330.0x32.0mm. - RHT = CP5200-802S4 / - LHT = CP5200-803S4. - RHL = CP5200-804S4 / - LHL = CP5200-805S4. - TO SUIT DISC Ø330.0x28.0mm. - RHT = CP5200-806S4 / - LHT = CP5200-807S4. - RHL = CP5200-808S4 / - LHL = CP5200-809S4. - TO SUIT DISC Ø304.0x32.0mm. - RHT = CP5200-810S4 / - LHT = CP5200-811S4. - RHL = CP5200-812S4 / - LHL = CP5200-813S4. Brake Pad Information (To view larger image of pad click on Pad Part No) CP3215D50 . Pad Area = 57.4cm³. Pad Depth - 50.3mm Thickness = 16.8mm TECHNICAL SPECIFICATIONS Piston Sizes - mm - Ø38.1 x 2 - Ø41.3 x 2 Disc Diameter - mm - Max = Ø330.0 / - Min = Ø304.0 Disc Thickness - mm - CP5200-802 to -805 = 32.0 - CP5200-806 to -809 = 28.0 - CP5200-810 to -813 = 32.0 Weight (no pads) - Kg 2.6 Hydraulic Threads M10x1.0 Mounting Type Radial Mounting Centres - mm 152.0 Mounting Offset - mm - CP5200-802 to -805 = 50.93 - CP5200-806 to -809 = 46.86 - CP5200-810 to -813 = 50.93 Mounting Hole Ø - mm 10.1 ‘PL’ Dimension - mm 60.36 Bleed Screw Tightening Torque 17Nm SPARE PARTS Pistons CP5200-802 to -805 & -810 to -813 - Ø38.1 = CP2409-124 - Ø41.3 = CP2290-50 CP5200-806 to -809 - Ø38.1 = CP2889-105 - Ø41.3 = CP3357-111 Seal Repair Kit CP4519-JK Anti-knockback Springs CP6518-4LBLL Pad Retainer Type / Part No Bolt / -CP5200-802 to -805 & -810 to -813 = CP5200-110 - CP5200-806 to -809 = CP5200-124 Pad Retainer Bolt Part No -CP5200-802 to -805 & -810 to -813 = CP3894-139 - CP5200-806 to -809 = CP3596-112 Wear Plates CP5200-306 x 2 CP5200-307 x 2 Bleed Screw CP3720-173 Fluid Pipes -CP5200-802 to -805 & -810 to -813 = CP5200-6 - CP5200-806 to -809 = CP5200-16 Brake Pads: Ferodo FRP216X Б/У Brake Discs: 5x114.3/330x28mm Б/У 1 мм. Стояли на супре... Скажу сразу, суппорта не отжатые... 60000 Рублей 89162228516 Владимир |
Лучше на altezza-club.ru выложи быстрее продашь,диски на Порше не подойдут по сверловке а машинки у Порша brembo в стоке стоят.
Текущее время: 07:50. Часовой пояс GMT +4. |
